Specifies mirror source filters for an instance.
| mirror_name | Specifies the mirror's name. |
| vlan | Specifies a VLAN. |
| vlan_id | Specifies a VLAN ID. |
| port | Specifies a port or slot and port. |
| port | Specifies particular ports or slots and ports. |
| ingress | Specifies packets be mirrored
as they are received on a port. Note: This
parameter is available only with port-based mirroring.
| ip-fix | Enables mirroring of the first fifteen packets of every IPFIX flow. |
| egress | Specifies packets be mirrored
as they are sent from a port. Note: This
mirroring.
| ingress-and-egress | Specifies all forwarded
packets be mirrored. This is the default for port-based
mirroring. Note: This parameter is
N/A.
You must enable port-mirroring using the enable mirroring to port command before you can configure the mirroring filter definitions.
Port mirroring configures the switch to copy all traffic associated with one or more ports to a monitor port on the switch. The switch uses a traffic filter that copies a group of traffic to the monitor port.
Up to 128 mirroring filters can be configured with the restriction that a maximum of 16 of these can be configured as VLAN and/or virtual port (port + VLAN) filters.
One monitor port or 1 monitor port list can be configured. A monitor port list may contain up to 16 ports.
Frames that contain errors are not mirrored.
For general guideline information and information for various platforms, see “Guidelines for Mirroring” in the Switch Engine v33.1.1 User Guide or the Usage Guidelines of the enable mirroring to port command.
The following example sends all traffic coming into a switch on port 11 and the VLAN default to the mirror port:
configure mirror add port 11 vlan default
This command was first available in ExtremeXOS 15.3.
The vlan_id option was added in ExtremeXOS 16.1.
The ip-fix option was added in ExtremeXOS 21.1.
